Heat treating procedure in barrel furnace vs forge vs kiln?
So I'm building a Don Fogg-style heat treating barrel with a thermocouple and pyrometer, where previously I've always used a forge. I've been reading Larrin Thomas's articles on forge heat treating, and I'm wondering whether this type of barrel furnace should be treated as more similar to a forge or to a kiln in terms of procedure?
On the one hand, a reasonable degree of precision can be achieved with this sort of setup which wouldn't be too dissimilar to a kiln I would think. You definitely can't do things like anneal something at 1200 degrees for 16 hours or anything like that to achieve a DET spheroid anneal, but Thomas says that after normalizing and several grain-refining cycles you can achieve a structure pretty similar to that, and with a barrel furnace you can certainly hold at austenitizing temperature for 10-15 minutes as is recommended in many heat treating procedures for hyper-eutectoid steels.
Note: this is for forged knives not stock removal, so there's no option to heat treat them in the annealed state that they come in when purchased.
What I call the “fast DET” anneal isn’t difficult to do without a furnace. For many simple steels you heat to non-magnetic and then place the steel in vermiculite.
Edit: the “fast” refers to the cooling rate which is much faster than the typical 25-50F/hr listed in datasheets. Typically something like 250-650F/hr which works for vermiculite. The slow rate is also DET, it is sometimes called a “transformation” anneal or not referred to by any name at all.
Hey Larrin Larrin would adding a big chunk of steel to the vermiculite in hopes of slowing the cooling down be helpful at all?
My current plans involve chef knives and 52100, so the chunk of steel might not be a bad idea. Thanks for chiming in in person, Larrin! Very much appreciated. It seems like given the level of available precision in a barrel furnace and that fast DET anneals aren't as finicky as I'd thought, I might be best off following your recommended heat treat as if I were using a kiln rather than a forge.
