Originally posted by Dan Harden
in the overall - simply deplorable.
Of the three latest ones
Very strange.
I have etched most of mine to visualize the zones.
In all cases they have been exactly as expected.
And very clear and well defined.
If your old kukris were tourist products
then no effort at hardening would be expected.
From other sources, who knows.
You don't specify the source of the 3 newer kukris.
If they are indeed from the HI factory then I'm
sure Uncle Bill will replace these under warranty.
Your discription makes them sound defective & atypical.
If the blades are from a different source than HI,
then your comments are irrelevent to the discussion
because there's no telling who, what, when, why, etc.
When the HI business first started many many years ago
they contracted production from a pre-existing factory.
They stopped doing so because they had to reject a large
proportion of the blades delivered due to just such problems.
The teapot method is a proven technique;
when properly done.
One of the reasons we trust HI products
is that we've seen the proof that these kamis do it properly.
That proof is both by using the blades and by etching them.
And sharpening & hardness testing them, to be more specific.
And, yes, as hoghead says, the tip/point is supposed to be soft enough not to chip.
Please clarify your sources for the blades you tested.
If it's one kami's production then we should watch out for his blades.
