Thank you. Just to make sure, you put them next to each other so that one part ends up above the other in the furnace, or are they end to end, or side by side?I put a set of parts (blade + spring) into one pouch. Sometimes I do 3 parts per pouch. Just depends on the size of the batch I'm heat treating.
Thank you. I was a bit concerned that the parts may shift and end up overlapping when they go in the quench plates, but that does not seem to be an issue.I tend to HT the blade and backspring in the same SS wrap with the backspring nested around the blade so it's one layer. When clamping in quench plates they act as a single unit. Of course they have to be tempered separately as the backspring tends to require tempering up around 1100°F to lower Rc to mid 40's
Ken, how much of a gap do you leave between the parts?I have found pressing the SS foil tight around the blade/backspring will hold them into place just fine. First temper together will work just fine. I also use my HT oven for tempering the backspring. Actually by the time the first temper in the tempering oven (PID controlled toaster oven for me) the HT oven can be cooled enough to the final temper.
That's exactly what I'm referring to as "nested". Blade touching backspring is no problem, or if there's a small space no problem either. Just what fits easy.The parts should all be flat in the envelope. They go into the envelope like this. It's OK if one is on top of the other vertically. They can touch. You might be overthinking it a little.![]()
