- Feb 5, 2013
What do I need to consider in addition to the usual when heat treating small, thin parts? I want to try making some small carving knives and very thin woodworking marking knives. I've got some of the thinnest 1084 Aldo sells but it it still about twice as thick as I want for the thinnest blades (it is 1/8th"). I'll try forging and grinding and see which I manage to do best. I have the feeling that heat treating might be tricky since the metal has so little thermal mass, if that is the right term - that it will change temperature much faster to match the environment (in forge, in quench, in air moving between forge and quench). I also am concerned about losing carbon on the surface since it is thin already and I've read a number of comments about the outer layer decarbing. I've got some clay I used to HT an odd, rasp-like blade a while ago - can't recall the name but it was suggested here). Would that help?
I also have a fair amount of 1095 that is only .025 or so, sold as rc 48 to rc 58 (card scrapers cut from scraps by a saw manufacturer). That is perfect for a few of the blades. Is that so thin I'll have problems? Anything I should try?
Thank you for any pointers, including of course suggestions to go read up - just please give me a hint what to look for.
