lasersailor184 said:
I tried to use the search, but it wasn't working.
So I was wondering what the process was to heat treat a knife and also why it works.
I'm gonna reply with a simplistic answer, but one which is relatively easy to understand.
Metal is made up of mollecules. In actual fact, there is a lot of "space" between mollecules in anything. Even in a solid object. Heat it up, and the mollecules dance, so much so that if you heat them up far enough, they show the properties of a liquid, and even more, and they turn into a gas. All that is happening is that the "space" between them is increasing. (Think in terms of ice / water / gas ... OK so far?)
Heat up metal and things happen, the mollecules dance, but when they cool down, they settle themselves into random patterns, or not. Hammer them hard, and they shuffle themselves into different patterns.
Copper metal is an interesting one for example, heat it up slightly and let it cool naturally, and then the mollecules will have settled themselves down into a random-ish pattern which makes the metal really soft and easy to hammer. Hammer it, and the mollecules dance into patterns, which makes it harder.
Steel isn't quite like that, it needs to be red hot to soften it enough to be workable..... but can you imagine what happens when it cools down, or if you hammer it when it is cold or too cool?
Therefore, after all the work has been done, a heat treatment is necessary to get those mollecules back into line. In fact into a specific regimented order, like little soldiers. Heat it up to a specific temperature (different for each type of steel and the type of hardness you want), so that the mollecules shuffle themselves into a certain pattern, and then quench them in oil (or water depending on the type of steel), and you literally "freeze" them there.
Viola! Steel that is of the hardness (and what is called "temper", without being brittle) that we need for the knife.
Rod
