heat treatment on leathermans knife blades?
does anyone know anything about the heat treatment leatherman (or whoever makes the're knives) puts on the're knife blades? if i were to point out one steel it would be 420HC, because they use it the most. any thoughts?
last i checked it was 420hc and no idea. but you can always call up customer service
Yeah it's 420hc. I'd be curious to know as well. Their hrc listing for it is a pretty large range
Rockwell hardness by steel type:
420HC: 55-59
154CM: 58-60
S30V: 58-60
late edit: They actually give a couple details on the same webpage...should've scrolled down further last time :p
420HC blades: Crater series
• Fineblank - precision stamping process
• Flat finish - takes off initial burs from the stamping process
• Heat treat - this is a Quench Bath heat treat
• Mass finish - round over the sharp edges
• Double disc grind - makes the blades very flat at a precise thickness
• Lock taper grind - precision grinding of the KB lock face (only on c3/e3)
• Hollow grind - grind the main bevels and false edges
• Bead blast - creates matte surface finish
• Sharpen
154CM blades: Expanse series
• Laser cut - 154CM is too hard to blank, so it must be laser cut
• Heat treat - this is a Cryogenic heat treat
• Machining - precision hole drilling and counter sinking operation
• Sharpen
• Buff
Depending on the line, it could be either 420HC, 154 CM or, in very limited models, S30V.
I seem to recall from the factory tour that heat treat, like anodizing, is not done in-house.
Sharpening is done in-house, one blade at a time, by robot arms. Super cool.
