Cobalt
Platinum Member
- Dec 23, 1998
Ok, in nearly 5 years of this forum, all of these subjects have been discussed time and time again. However, whether your an Engineer/Knifemaker/Knife user-tester there is obviously a lot of factors here, so I await some comments based on experience with knife using-testing, making and Engineering.
As a mechanical/materials Engineer, I studied much concerning properties of metals and other materials and have teste knives that have proven whats in books and have tested knives that has disproven what's in books, so here goes my commentary and question:
Lets take two steels, D-2 and O-1. the Charpy value of D-2 at 60Rc is 23. The charpy value of O-1 at 57 Rc is 32, so these two steels are very similar in Charpy value. The way Charpy works is a test sample of the steel notched and impacted to fracture. however, the steel is heat treated to whatever Rc is desired. The Heat Treat used, I am presumming is from the steel's MSDS. So who determines if the heat treat given to the steel prior to testing was the best possible treatment and can't it be improved upon. I guess what I am saying and wondering about is whether the numbers given really mean much in a business where heat treatment can be so complicated and much better than what the standard is on the test samples. for example, test samples are not cryo'd. Test samples, are not differentially tempered, nor are they subjected to a Top Secret heat treatment that improves the steels performance. It seems to me that many of todays steels perform much better than their specs dictate and some perform much worse. So do the numbers given and spoken of so often really mean anything or is everyone just using them as a baseline.
So in comparing lets say carbon steels or even the two steels above, D-2 and O-1, charpy values would not be enough. The best possible heat treat for each and made in an identical knife would be the only real way to determine which steel performs best in toughness and wear resistance.
Hopefully someone is awake and willing to read this boring thread.
