Heating Steel
I have a question about heating steel. Is there any way to get steel hot enough to work without a forge? I want to try my hand at making a tomahawk without buying special tools. I have general shop tools.
swamp
For small things you can just use a torch, but a tomahawk is too big for that. You don't need to buy anything to make a charcoal or coal forge if you have decient scavenging skills though, and only the lining would need to be bought for propane.
awP told you what you needed to know when he said charcoal, you will need a blower like a hand held hair drier and a pretty deep pan to put the coal in and fire up, also lots of charcoal. I started out forging using charcoal, made a simple forge out of an old BBQ I had. I placed a pipe in the center for my air supply tube, I Attached a gate valve on the end that I attached a hair drier to so I could control the air flow and it got plenty hot. I never made anything but railroad spike hawks then because they were small and could be made with a lot less numberof heats need to get to or close to welding heats when you split and drift the eye hole, but then after that, a good hot forging heat is all you'll need. Have fun, but watch out, that fire and steel pounding is very addictive.
Bill
Thanks alot for the info guys. I kinda suspected what yall said about the hawk being too big to work without a forge.
I have another question that I have always wondered about. My grandmother has an old small forge that has been passed down through her family. It has its own stand, a crank, belt drive blower and it is aprox. 18 in. dia.
If this thing gets hot enough for forging, why doesn't the coke burn through the forge?
swamp
A) heat rises
B) cast iron firepots are usually intended to be lined with a clay of some sort
C) hot enough for forging isn't hot enough to burn through, you'd need to be messing with welding heat alot to risk that
