Heavily used knives: How often do you actually SHARPEN
When i say sharpen, i don't mean a quick edge touchup on a strop or sharpmaker. I mean either stoning or using whatever machine setup (wicked edge, edge pro, etc) you prefer.
I haven't had to sharpen any of mine in about a year, and several get used 4-5 times a week
Not often for most of 'em. My most hard used knives are a Mora and an EnZo Birk 75 (S30V). The Mora holds a working edge for far longer than is reasonable for such a cheap knife and the S30V holds an edge exactly like you'd expect S30V to hold an edge.
Don't usually have to put mine to the grind wheel very often unless they have some nicks in the edge, or for my kitchen knives, whenever the wife forgets and uses them to cut something on a ceramic plate or the counter top instead of one of three cutting boards we have. I just run my blades on the slotted wheel of my paper wheels and they are back to shaving sharp. I am a bit OCD about my knife blades and keep them sharp at all times.
Blessings,
Omar
I work on the back bevel 1-2 times per month but maintain the edge about 2-3 times per week. it really depends on the steel for me. I also reallllly enjoy sharpening, but I could probably go half a year without touching the backbevel, but I like keeping the micro/edge bevel small as it should be
My PM2 gets stoned every few weeks. The S30V loses its "zing" after a day or two of use on plastics and some cardboard. After that, more force is needed, causing micro chips to form along the bevel. That's when the stones come out and metal is removed.
As BePrepared knows, the Benchmade Contego is a different beast. I set the edge on that M4 about a month ago and haven't even needed to strop it. This is after a few trips into the woods to blow off steam on the local fauna. I just come home, clean it with dish soap, and apply a light film of mineral oil.
I have used my contego every day this week for everything from cardboard to hard plastics (and some wood) and it still shaves effortlessly. I don't know if it ever gets dull
Well I still use my edge pro to touch up/polish the edges on my commander, sebenza, and sng so I guess thats technically sharpening. As for using coarse stones (400 grit or less) to repair edge damage, maybe one a month/every other month? I work in an industrial warehouse so my edges can get rolled/dinged more often than most
Whenever needed really.
Sometimes weekly, depending on what work I do with it.
More often though, I touch up about once or twice per month of usage at work
I touch up my PM2 or anything else I'm carrying at the end of each day of use, so it never needs hard sharpening. Be prepared, right? Haha. The longer it is put off, the less important it will become until the edge is "suddenly" dull as a butter knife.
Once the bevel's set, I seldom do more than a few backhone passes on the Washboard a couple times a month. If I use it heavy, for me 5-6 times in a day, I'll touch it up once a week or so. I'll generally strop most of my edges more to remove tape residue or tarnish than to actually sharpen it. If its three finger sticky and shaves arm hair, I don't touch it.
My kitchen knives get sharpened more often, the cheap ones will be touched up on a coffee cup almost every use, the knives in my better set maybe once a month depending on how much cooking I'm doing. The more vegetarian stuff I prepare, the more often I have to sharpen them. Even then, I don't take them to a stone, just a handful of passes on the WB and they're back to scary sharp. Was reflecting on this the other day, I need to study up on how to properly chop foodstuffs - the edge caught on my fingernail as I was dicing away with my 10" chef's knife and went about half way through. That was close. This is the same knife that nearly ruined a watermelon this summer by chopping some of the seeds in half when I cut it down. Much easier to spit out full seeds than half ones...Note to self, don't use your sharpest knife to cut watermelon.
My Contego is just now showing signs that it needs a touch up. I sharpened it a number of months ago at around 30º inclusive, although that may be off a few degrees. I use it on cardboard, plastic and have even cut some zip ties (I know) and other meanies.
I have done absolutely nothing to the edge since sharpening. I have a feeling that stropping won't do much to the hard m4 so I haven't bothered.
I'm very much considering bringing the angle down to around 25° to see what happens. I'm also considering sanding off all of the coating. The only reason I haven't is because I know I'll miss the lettering. I really REALLY want an uncoated, patina'd 810 though. :o
My kitchen knives see a polisher (8000) once a week and a coarse (400) twice a year.
these are work knives by the way, my home kitchen knives maybe few times a year on polish.
I touch up almost daily, with light EDC use, on my 8Cr knives. Rarely do they go back to stone unless they have chips, etc.
Washboard and Balanced Strop are what I usually need.
When I hit something with them that I shouldn't have.
Chris "Anagarika";12658824 said:
I touch up almost daily... Rarely do they go back to stone unless they have chips, etc.
That's definitely the best approach. :thumbup:
