Cliff Stamp
BANNED
- Oct 5, 1998
Tried some batoning to cut a sapling to length, very time consuming. With the lock engaged even light impacts will just push the ring down and compress the wooden handle. The work has to be done then with no lock and just batoned right above the point of impact which reduces it to shallow cuts, working around the wood to notch it to allow it to be broken. Faster than carving a notch, but about 10 times as long as even a moderately powerful chopper like the Ratweiler.
Batoning to split isn't thus productive as only the start cut can be made and even trying to cut off small slabs isn't productive and they can't be pryed off significantly either. Even a slim Mora is in another class in regards to strength as are any of the modern tactical folders which are far more efficient for this type of work. I carved a piece of deadfall into a small wedge but unfortunately so much of it was rotted that I ended up with a very small splitter and it took three attempts before I broke off a decent slab :
Once the first decent slab was broken then it is easy to take apart the rest of the round :
The opinel shines at carving, it reduced one of the slabs into very fine shavings, so thin you could almost see through them. This wood was fresh and thus wet, but paper thin it dries extremely fast. It was also hot here (meaning above 20) which helps. This is one of the cases where it benefits to prepare tinder before the rest of the fire wood :
Once it is going it is of course fairly trivial at that point to continue :
-Cliff
-Cliff
