Helko Vario 2000 axe or hatchet?
afishhunter
Basic Member
Anyone have one?
I kind of like the idea of being able to change the head for different jobs (felling vs splitting, for example) and being able to change the handle length as needed - without the change to a shorter handle being "permanent".
Are they worth getting, or are they a novelty that does not last or work as well as a conventional axe or hatchet?
Anyone have one? . . .
I don't. In fact I didn't know about them until this post and looked them up. They look interesting, hope someone has some information to share. Sorry, no help.
Seems like they would take away the excuse for getting more axes. :D
I don't have one and I have to say I wouldn't go out of my way to try one. Frankly, when they attempt to take the skill requirement out of any piece of technology there are generally a lot of unforeseen problems.
A couple thoughts on what these might be:
- Given the through construction of this I would be worried about resonance. Would it not defeat the purpose of a wood handle and eye construction of traditional axes? I realise there is some sort of connective material here which may be very good at absorbing shock, and this leads to...
- More parts, more connecting points, more possible things to go wrong and have to replace.
- The geometry looks poor to fair, with the problematic connection points which could cause hangups for some tasks.
But with a little searching I found a review and multiple bladeforums links:
http://rockymountainbushcraft.blogspot.ca/2012/04/helko-vario-2000-convertible-axe-system.html
"Pros- Revolutionary design that actually works as intended, well-tempered German steel, attractive, post-modern looking design, German quality, $5 shipping!
Cons- Flimsy sheath, heavier weight than traditional axes of the same size, expensive replacement bolts, edge is on the thick side"
http://www.bladeforums.com/forums/showthread.php/944085-Helko-Vario-2000-Axe-Review
There is a fair bit of information it seems. I wouldn't take comparisons to Fiskars as a good sign though as the resonance can tear up your arms a bit. I think that's what you should mainly look out for with this axe in the reviews.
I looked at their ads and it's not something I'd ever run out to buy. They aren't expensive though and are bizarre looking enough that theft isn't going to be a problem, such as you'd have with an expensive Swedish boutique jobbie.
In USA a general purpose axe for recreational use is what's called a 'boys' axe. These have 2 - 2 1/2 lb heads and 26" handles. Were I able to swap a 2 1/2 lb head over to a 5 lb splitter the handle would be way too short, and were it a 36" handle for the splitter, a swapped-over 2 lb head would be a joke. I can see the merits of interchangeable heads of same or similar weight, one for cutting cross grain and one for splitting lengthwise but otherwise I don't see any of this as much more than a marketing gimmick.
I wonder about the balance of the axe since there is no poll. Would a more closed hang make up for it? Just not sure.
