Tip: shape the front of the scales before you glue them. You can't finish the front without scratching the blade after they are glued up.
A lot of makers start out as "handle smiths" or kit builders, as it is a fairly simple and low cost way of customizing your own knife and getting an idea about one or two of the steps involved in making a knife and/or sheath.
The "stickies" as mentioned, will provide more than enough info to get you started and finished. Heck, even the instructions that come with your kit knife will likely be all you need. I'd say at minimum, you'll need a wood rasp (and/or file) or two, some sand paper in various grits, some two part epoxy, and then something to seal the wood after your handle is shaped.
Where you stop with the sand paper will depend on how polished you want the handle to be. And don't skimp on quality abrasive paper. A good paper will pay for itself.
