Helle, Gransfors and a fire
Pr3inar
Todays line-up
Splitting some birch
Pose with the end result
Fossekallen and Wildlife hatchet
Some whittling while the fire catches on
Ta-da!
I have a small forest axe. Like it a lot. Good for one or two hand use. Head design is perfection and the overall build is top shelf. Just a really good tool.
I own the Hatchet.
It’s really nice.
I probably should’ve bought the small forest ax instead, only because it would’ve suited my purposes better.
The way the head just glides throug branches with a small flick of the arm, and still beeing reasonably able to split a log the thickness of my upper arm lengthwise makes it my favorite item to bring! I guess the SMF is even more capable, having a longer handle
I always enjoy your posts/pics... tools at work.
I'd also recommend checking out the Small Forest model. As mentioned already, all the benefits of the hatchet with a bit more handle for bigger jobs. Works equally well both one or two handed but still small enough to carry around for a day in the bush. I have a few, and have also hung some older (non GB) heads on a GB small forest haft because of its perfect size.
The Helles are great as well. My Gaupe fits my hand like a glove and is a joy to use. Also check out the Temagami, its full tang and can take a bit more abuse... but you're already carrying an axe so maybe less important.
Looks like you're already enjoying yourself out there anyway.
Thank you very much!
I have considered the SMF many times, but don’t know if the difference from the hatchet is big enough to justify it..
I have the Temagami, but because of the sheath I just end up carry the Fossekallen (or Mandra) more often. Still a great knife tho’!
I love Helle knives; have a dozen or so plus the knives I've crafted using Helle blades. Their laminated blades are fantastic!
Enjoy your warm fire.
Rich
