hello all
hello all, new to the forum.
im also after a bit of heip.im looking for a new pair (or 2) of pb washers for a zt 0350,
also a torsion bar, which has broken,and yes i am aware that fairly soon,i will have to
remove said bar,but for now would like to get back running properly .
i have tried kai cutlery,but they will not ship to uk. does anyone know where i may be
able to procure said items.
many thanks s.
Welcome! Don’t know about the torsion bar, but washers usually have 3 dimensions: thickness, diameter, and hole size. If you can gather those dimensions, you can order from knife maker supply purveyors. Good luck.
was hoping they would be "off the shelf" for the zt 0350, can get id and od, but they have worn, so the orig thickness ,i will not have :(
Take a look at what is available at a knife makers supply place. Find a set that is a little thinker than what the worn out ones are. You could actually buy a couple set of washers with different thickness. I would not go too much thicker than your worn washers.
You could always contact Zero Tolerance and ask what size you need.
