- Jun 19, 2018
Hi Everybody!
I am somewhat new to knife making and very new to posting on the forum..
I am putting myself out there on this forum in hopes learning, and hopefully not getting smacked too hard by the experts,
so please critique me, but please be nice. (in my experience people tend to be harsh on the internet because of anonymity.)
So a brief history of my experience. I have been putting my self through youtube university, and studying lots of posts on the ol interwebs.. Got into this about 2 years ago. Made a couple knives with just files and sand paper, acquired some tools, ruined some knives, built a forge, kept at it, had some successful knives too, got some more tools, pissed off the wife, cut my self a few times
, ruined some more knives, .. you get the idea.
so I made these three recently.
I really wanted to get into damascus so I bought some and jumped right in.. but i also have the same issues with 1084.
heres what i need help with..
The transition from scales to blade.. my first few knives I was trying to shape the scales after attaching them to the blade.. a greenhorn mistake for sure. as I progressed I figured out that i need to finish the scales as much as possible before attaching.. the Damascus Chefs knife is a good example of my earlier attempts of shaping after attaching.. you can see the transition there sucks.. the smaller knife I took the handle scales to a much more complete state before attaching. but my transition i think could still be better.. any suggestions here would be much appreciated.
saving the best for last.
my concern is that the edge does not seem to last very long.. I sharpen till it shaves my arm hair.. then for example if I cut up a few veggies, and then slice up some meat say for a soup or a sauce for 4 people, the edge will have lost its ability to shave. it will still be sharp enough to slice a tomato with out squashing it mind you.. how long should the edge last?
the steel i got from a well reputed dealers.. as i said the santuko is 1084, and the damascus blades are 5160, 52100, 15n20, and 203E
I suspect my HT method.. and indeed if it is my method, is there a way to fix these knives? because i really really like them..
Prior to HT i take the blade to a 400 grit and get it really close to final bevels and shape.
I heat til non magnetic, then a minute more.. then I quench in mix of coconut and peanut oil (left over from thanksgiving last year). then i file check.. both of these knives the file skated easily across the blades.. i temper for two cycles of one hour in a 375 degree oven on bake (lower element) with the blades on the 2nd to top rack.. the oven back wall at that height measures 360 when i shoot it with my laser thermo meter.. after that i finish the blade being very careful to not over heat, and attach my handles and final sanding and buffing, mostly by hand..
If I had to guess I would say I need a longer soak time in the forge.. maybe im not quite reaching 1525 F? should I change my quenchant? or is my edge performance close to what it should be with this type of steel? should i rethink my temper method? I annealed the steel prior to grinding, but i didnt normalize be for HT.. was that a contributing factor?
Thanks in advance for any helpful info you care to throw my way.
