- May 16, 2018
Mate i cannot help, but i really hope somebody can, that looks nasty.View attachment 1635273View attachment 1635276
Well I discovered that the pile side cover is warping significantly, and both are slightly raised at the bolsters. I had actually lost it for a couple weeks, finally found it today under my recliner. I'm thinking it's a humidity issue but how do I fix it??
Thanks for any suggestions!
Thanks, I wouldn't be to worried about water damaging the metal, the frame is titanium and the spring and blade steel is stainless. As long as the heat stays below the temper threshold of the steels. Also it being screw construction perhaps I can remove it,boil it then clamp to a rigid flat surface.Maybe try to heat it first, with a heat gun, before attempting to clamp it. I think horn is usually boiled first, or perhaps steamed, but I'd not want to risk the water damage to the metal.
Greg
Im intrigued...whats theory behind chapstik horn unwarping??Not sure if this would work with ram, but I’ve had some success un-warping Buffalo horn with chapstick.
Very unpleasant. I'd be very careful of attempting to clamp it unless it's sufficiently moist, even then flaking or a break could occur. You might try soaking it in water overnight to see if here's any swelling, as you note, rust will not be a problem.
Mufflon is generally very durable stuff but it can of course vary. Is it very dry and hot where you live?
One idea might be to e-mail Viper and ask if they can recommend a course of action ?
Hope you can get it back to where it was as these are very decent knives, in my view.
Thanks, Will
