Help a Bando man with blade scratches.
This message was sent to me via personal email and I have edited it slightly to protect the identity of the sender who gave permission to post this. I sent my own personal opinion about the scratches but I know some of you experts can offer more ideas than me so if you have a minute help this fellow out.
Uncle Bill
I received the 15" Sirupati last week. As a result of already receiving a 20" Sirupati, the quality of the 15" was not a surprise. I used it this weekend to harvest bamboo from some local groves.
The local Boy Scout troop that my son and I belong to plans to build a 15 - 20 foot tall drawbridge at next weekend's Camporee. My son, another Scout and I collected bamboo ranging from 10 feet long and 1.5 inches in diameter to 35 feet long and 4" diameter.
The kukri was used mostly to trim the brush off and top the pieces, which it did very easily. I did discover an old one inch rusty wire cable in the midst of one clearing cut and nicked the blade near the tip....probably a nick about the size of a grain of sand...easy enough to see. I used a diamond hone pocket file I keep with me to dress it and then gave it more attention when I got home later. There is still a very slight indentation but not enough to impair use...the supplied karda did a good job of helping dress the edge.
After working through about 30 pieces of bamboo the blade was still VERY sharp.
The scabbard was very tight...I used a metal tapered dowel inserted into it overnight to stretch the leather, then pushed it in a little further the next day. It is loosening up nicely.
The kukri was a pleasure to use. Thanks for providing such a fine piece of equipment.
One question...there are some very light scratches all along the blade from the bamboo that are difficult to remove (maybe actually from dust/dirt on the bamboo canes...I did not "cut" any dirt). Which of your regular forum guys can tell me the best procedure to bring the blade back to the original pristine sheen and shine? I have a buffing wheel and have used the supplied brown and white "rouge" but that has not removed the scratches.
Wet/dry sandpaper. It comes in a variety of grits. Commonly available in any hardware store up to about 600 which produces a fine finish and up to about 2000 thousand in an automotive store which gives a mirror finish.
However if you are going to be using the khukuri on a regular basis - well, you are in for a lot of work keeping the polish up.
-Cliff
Thanks, Cliff. I'm the same. I just leave the scratches because I know next time out I'll put more on the blade. I try to avoid those never ending battles.
Uncle Bill
I've found that by applying a nice satin finish (using the wheel and rouge), you can "mask" the scratches. I've sold many of my khukuris (Gurkha House) to some of my customers with this kind of finish applied. I find that it is better than a mirror finish for those who want to use their khukuris and not just put them in their collections. So, try to apply a satin finish and see what you think.
