- Jan 10, 2002
Im currently experimenting in sword making. Used the rear coil spring from a dump truck from hades; coils on this bad boy were almost as thick as my thumb. Spark tests were and orange yellow fourth of july scene before any work was done on the steel. Hammered this stuff out at cherry red; and it was HARD to move even red hot. Quenched to blue hard in water. On both ENDS of the blade fracture occured; small pieces about 6 in long.
We took one of the broken pieces and created a halfbutt chisel/knife edge w/ a grinder and whetstone w/oil. Split a pine 4x4 end on; whittled shavings off; still sharp no edge damage. With proper safety equipment in place (of course)hammered & cut/chisled "mushroomed" edge of a work hardend old bronze/brass hammer with only minor edge damage to the test piece (minor grinding w/ "miracle wheel" those things rock!!)"rehoned"; "Vise-d up" a chunk of structural steel; and repeated cutting/chisel routine w/hammer; and dinged edge;but again reperable. On both the brass and low grade steels the "knife" would damage both mediums with hand pressure only and still hold a serviceable edge.
We threw the remaining 55 in of raw matl. on the floor; no shatter;slammed it into a vise stand bolted to a concrete floor no effect; Whacked it across the tongue of the anvil; no breakage, springs at hand pressure and goes bak into shape. Only thing we cant figure is why the breakage at both ends at almost xactly the same "spots". Any help you have on this would be most appreciated
