I like the idea of a hand held fixture for aligning the sharpening stone to the blade, like Smiths, DMT and Lansky's setups use, but it seems like all of them are just a little off, I can't get them to work quite to my satisfaction. I own a smith's setup and just got a DMT setup because I wasn't happy with the smiths, now I'm wondering if there's some intrinsic problem with the design.
Smiths- rigid, strong, well built, holds blades well and the angle doesn't change with the clamping motion. Doesn't tend to get i it's own way even with small blades. All of this adds up to a very repeatable grind. So why did I decide to try something else? Since the guides only attach to one side, you always get a slightly different angle on both sides of the blade, there is no way around it with this design. I marked it so i always put it with the point of the blade facing the same way so I always get the bevel offset to the same direction, but I got tired of always having a slightly crooked looking blade.
DMT- I though this would fix the problem with the smiths, the guides mount to both sides so they're always offset the same on both sides. Well great, but it doesn't hold the blade as well, doesn't have the little recess that the blade seats in on the Smiths. If you cut one I suspect that it would weaken the thing enough to make it not as useful or break. It does have some little guides that you can press against the spine of the knife, but with most EDC size or smaller knives they are too far back for the small blade/the blade does not stick out far enough to sharpen. It's also bulky and gets in it's own way, and in no way repeatable (by the time you fudge it around enough to be able to sharpen the whole edge you don't know how close you are to the original. Since the angle changes with the clamping motion that isn't repeatable either (but that's the least of my problems.
I'm worried that the Lansky one is going to land somewhere in between, and still not right.
Suggestions? How to make one of these work repeatedly?
FWIW, the DMT diamond stones and holder are awesome, I love the extra course black one that I added to it for quick work of re-profiling an edge. The smith's ones are Ok, but not nearly as nice. Because of the offset of the smiths setup they are not interchangeable without changing the edge angle. Grrr...
