The General is right, it would help a lot to know what type of knife is giving you trouble. On the other hand, if your knife just has too obtuse a grind angle and you haven't been actually removing material at the edge, you can probably diagnose this by yourself. Paint the sides of the edge with a black marker or paint. Try some swipes on your Sharpmaker in your usual manner. See if the shiny line where you removed ink is at the edge or behind the edge. If it is behind the edge your bevel is too obtuse for your Sharpmaker rod angles. See if you get better results with the rods in the more open V (higher angle) position in the Sharpmaker.
If your sharpening is not reaching the edge (your ink was removed away from the edge) you need to remove more blade material (known as reprofiling the edge). Reprofiling is hard to do with the comparitively fine grit of a Sharpmaker. You may want to get a simple silicon carbide bench hone and work free hand to get rid of the ink. If you worry about scarring your blade while trying this, put some tape on the side of the blade and only leave 3/16-inch or so behind the edge exposed.
[This message has been edited by Jeff Clark (edited 03-21-2001).]
