I am a newb. I have reading about and collecting knives for about 2 years. I have the bug to start making my own. I getting ready to order a coote 2x72 with an 8 in contact/drive wheel. I am also making my own forge.
1)I would like to know what steel I should try to grind my first knife? It will be a moderate size camp knife.
2)Do I use 1/8 round barstock in my handles if I drill a 1/8 in hole? I know that sounds like a dumb question I just want to make sure I dont need a slightly different size for the best fit?
Thanks
1.
If you want to heat treat it yourself, get some 1084FG from Aldo
If you ship it out for heat treating, you can use any suitable steel you want.
2.
Not a dumb question.
If you drill a 1/8 hole, you will not get 1/8 pin to easily fit.
You will need to get a # drill just a little larger.
http://www.carbidedepot.com/formulas-drillsize.htm
1/8 is .125
# 30 is .1285
.0035" larger
or you can spin a bit of pin in a drill and sand it down.
That will help the epoxy to stick to the pin too, but you can put the pin out of round doing this.
1/8 pins in a large knife may look small ?
You may like to start with a smaller knife for your first one
Have you seen this ?
The Standard Reply to New Knifemakers v11
The answer to a 13 year old student is different than to a 40 year old engineer.
We may recommend a local supplier, or you may have a helpful neighbour; but that depends on where you are.
Fill out your profile with your location (Country and State at least), age, education, employment.
Look at the threads stickied at the top; many are expired, but not all.
The basic process in the simplest terms
Absolute Cheapskate Way to Start Making Knives-Printable PDF
Absolute Cheapskate Way to Start Making Knives-Website
Web Tutorials
Detailed instructions by Stacy E.Apelt
The Things I Advise New Knife Makers Against-Printable PDF
Handle Tutorial - Nick Wheeler-Website
Books
A list of books and videos on the KnifeDogs Forum
http://www.knifedogs.com/showthread.php?t=5285
BladeForums - E-books or Google books
http://www.bladeforums.com/forums/showthread.php?t=603203
I like:
David Boye-Step by Step Knifemaking
Tim McCreight-Custom Knifemaking: 10 Projects from a Master Craftsman
These are clear, well organized, widely available and inexpensive too.
Knife Design:
On the Google books thread, you can find
Lloyd Harding drawings
and
the Loveless book with large variety of proven classic styles.
Google books thread
Forging Books:
Lorelei Sims-The Backyard Blacksmith
An excellent modern book with colour photos for forging in general - no knifemaking.
Jim Hrisoulas- has 3 books on forging knives. Check for the cheaper paperback editions.
The Complete Bladesmith: Forging Your Way to Perfection
The Pattern-Welded Blade: Artistry in Iron
The Master Bladesmith: Advanced Studies in Steel
Machine Shop Basics -Books:
Elementary Machine Shop Practice-Printable PDF
Machine Shop Tools-Printable PDF
The Complete Practical Machinist-Printable PDF
The $50 knife Shop
It confused me for a long time.
Forging is NOT necessary; you can just file and grind to create a knife (stock removal)
The goop quench is total Bull, commercial quench oils are available, even grocery store canola oil works much better.
Junkyard steels require skill and experience to identify the steel and heat treat it properly.
You can buy proper steel like 1084FG from Aldo very cheaply.
I like cable damascus, but that advanced project has no place in a beginners book.
The home built grinders are the best thing about this book, but there is now a huge amount of info for 2x72 belt grinders on the web, including free plans.
Videos
Heat Treating Basics Video-downloadable
Right click and save this. Watch it once a day for 10 days and you will understand it much better.
http://www.archive.org/download/gov.ntis.ava08799vnb1/ava08799vnb1_512kb.mp4
Many specific how to knifemaking videos are available, some are better than others.
The best overall Knifemaking video I have seen is
Steve Johnson-Making a Sub-Hilt Fighter
The best video on leather sheath making I have seen is
Custom Knife Sheaths -Chuck Burrows - Wild Rose
-(Paul Long has 2 new videos, his sheath work is fantastic. I hope the videos are too)
You can see a list of videos and reviews at this rental company; some are worth buying, some renting
They are slow to get new titles and wait times are measured in months,
http://smartflix.com/store/category/9/Knifemaking
Green Pete's Free Video
Making a Mora bushcraft knife, stock removal, hand tools, neo tribal / unplugged heat treat.
"Green Pete" posted it free using torrent files.
Greenpete Knifemaking Basics-on TPB
You can also find it on YouTube broken into 4 parts.
Draw Filing Demonstration
YouTube video -Draw Filing-for a flat finish
Steel
The welding steel at Home Depot / Lowes
is useless for knives.
If you send out for heat treating, you can use O1, A2, D2, CM154, ATS34, s30v, 440C, plus many others.
If you heat treat yourself, find some 1070, 1080, 1084,
1084 FG sold by Aldo Bruno is formulated just for knifemaking.
You can find a list of suppliers here
http://www.bladeforums.com/forums/showthread.php?t=699736
Aldo is highly rated.
http://njsteelbaron.com/
Heat Treating
You can send blades out for heat treating at $10 or $15 per blade for perfect results, and avoid buying the equipment.
This PDF brochure gives a good overview
http://www.buckknives.com/resources/pdf/Paul_Bos_Brochure.pdf
http://www.petersheattreat.com/
http://www.texasknife.com/vcom/about_us.php
http://www.knifemaker.ca/ (Canadian)
http://www.bladeforums.com/forums/showpost.php?p=9143684&postcount=7
Grinder / Tools
Hand Tools
You can do it all by hand with files and abrasive cloth like the Green Pete video.
Photo of a nice bevel filing jig .
http://www.flemingknives.com/imagesPrime/FileStation/KPicB007.jpg
Entry Level Grinders
Many makers start with the Sears Craftsman 2x42 belt grinder.
http://www.sears.com/shc/s/p_10153_12605_00921513000P?prdNo=3
Commercial Production 2 x 72 Belt Grinders
http://www.prometheanknives.com/shop-techniques-3/grinders
Mapp arm Grinder Toolrest
http://www.bladeforums.com/forums/showthread.php?t=466024
DIY 2 x 72 Belt Grinders
KMG Clone
Free Plans
http://www.dfoggknives.com/PDF/GrinderPlans.pdf
NWG No Weld Grinder
http://www.usaknifemaker.com/plans-for-the-no-weld-grinder-sander-nearly-50-pages-p-723.html
EERF Grinder (EERF =Free backwards)
Free plans
http://wilmontgrinders.com/EERFGrinder.aspx
http://blindhogg.com/blueprints.html
http://www.atlasknife.com
Buy the kit
http://polarbearforge.com/grinder_kit.html
Safety Equipment
I have a sign at my shop door, Eyes, Ears, Fingers, Lungs as a reminder to take off jewelry and put on my safety gear.
Respirators
Those paper paint masks are about as effective as using a sock for a condom.
The minimum I would consider are the 3M and North silicone half masks;
even better are the powered positive pressure fresh air systems.
http://www.bladeforums.com/forums/showthread.php?t=788837
http://www.bladeforums.com/forums/showthread.php?t=726309
