Excellent point. I should have taken before/after pics... :-(HeyOyster ! Can you upload pics?
Are you saying that the edge doesn't meet until half an inch from the guard? I try to keep that distance at around a quarter inch. I can regrind that knife for you or re-edge it if it is that far from the guard. I can have Phillip get you a shipping label if you'd like.
If I ground the plunges 90 degrees then I could get the edge all the way back. It would also weaken the knife and create a stress rizer/snap point. Steel doesn't like interior 90% angles. I see a lot of knives with feathered plunges. Some of these are almost an inch of plunge. I try to keep mine as tight as I can to give strength to the blade and get the edge as far back toward your fist as I can. From the guard there is thicker metal than there is at edge. In order to keep the edge bevel roughly the same width, I work at a higher angle till I get to the edge, then begin using the edge angle. My goal is 15-20 degrees per side. If you are trying to move that edge all the way back to the guard, then you are going to remove a lot of steel from the plunge and your edge bevel is going to get wider, and IMO ugly. No knifemaker I know does this to their knives. Lots of knifemakers remove this issue with an awful choil. This choil not only removes a lot of edge strength by completely removing the support structure in one direction from the edge, but also creates a spot for skins, cloth, string, rope, and strapping to get wedged into. I opt for strength. I try not to sacrifice much of the edge length for it. Certainly a fraction of some knives with gradual plunges. A choil would take up almost as much edge length. Anyway, I wanted to explain the process and my thinking here. All of the steps relevant to this are done by me.
I’ll also add that I share Andy’s dislike for sharpening choils and that I understand his reasoning for why the blade shouldn’t meet the plunge line at a 90 degree angle. While I was able to bring the sharpened edge back closer to the ricasso, it still tapers out and into the guard with the structurally important curves on either side (if that makes sense - as a relative knife newbie I sometimes struggle with the vocabulary).
Again, thanks to everyone who shared thoughts, advice and encouragement with this newer member.
Cheers!
