- May 18, 2008
I have been working on my routine with a DMT aligner kit. I have been working at it for about 3-4 months now and I have it down to a point where I can get an edge to easily shave hair and 90% of the time whittle hair with some effort and it's a short whittle, meaning it doesn't slice into the hair for very long, its more like it just catches and splits the hair, but doesn't really whittle it.
I understand that hair whittling isn't necessarily an indicator of long term edge performance or even real world application, but I am just curious and have a desire to get a very refined hair whittling edge.
Typically my routine is as follows:
I use all DMT stones. I make sure that the knife is securely clamped and does not move. I use light pressure and decrease pressure as I go up in grits.
XC: get a burr on one side and flip to the other side. Reduce burr until not very noticeable with hand
F: get a burr on one side and flip to the other side. Reduce burr until not very noticeable with hand
EF: get a burr on one side and flip to the other side. Continue with this stone alternating sides reducing the number of strokes per side from 5 to 1 stroke per side and alternating each stroke in order to get the most minimal burr. For the last step I use only edge leading strokes to try to minimize burr formation.
EEF: get a burr on one side and flip to the other side (it's usually hard to detect the burr at all, sometimes I use a 30x loupe to check the edge for a burr). Continue with this stone alternating sides reducing the number of strokes per side from 5 to 1 stroke per side and alternating each stroke in order to get the most minimal burr. For the last step I use only edge leading strokes to try to minimize burr formation. I finish with 10 alternating stroke (1 per side) with most minimal pressure while still maintaining positive contact with the edge.
For the entire duration I use the clamp, I am careful to make all the strokes a consistent angle.
Strop: Finally I strop 20 strokes per side using green compound applied to a flesh (suede) side piece of tooling leather with a hard wooden backing. I use a VERY low angle, likely not making full contact with the apex at each stroke. I try to maintain very light pressure, as light as possible. I use such a low angle because if I start increasing the angle then I notice degradation in the edge compared to no stropping at all. I finish with a final 10 strokes per side on bare leather skin (smooth) side up.
I most recently used this method on a small Buck Vantage Pro (S30V). I use the lowest angle setting and I use a zip tie spacer. The resulting edge angle is between 32-34 degrees inclusive (based on DMT's FAQ on aligner angle settings).
With the above method I was able to achieve an edge on the Buck that shaved well and would whittle hair inconsistently (as described above). I notice that the edge does last a decent amount of time, I am just curious, what do I need to do to achieve a true hair whittling edge (even if it degrades very rapidly after initial sharpening). Or is just a matter of more practice and more patience?
