- Jan 26, 2002
Just got a JKM-1 by Shanker (I think...trisul)
Ordered a K.K., but with the one-day deal before Uncle's trip, I ain't gonna complain, and it ain't worth sending this much steel back and forth--Man, it is a tank. A little longer and even more massive than than the one I have by KNN. A micro-tank.
Here's the catch--the horn has shrunk and BOWED.
It's in contact with the tang at the ends, but that's about it. You can see daylight between both slabs and the tang. The rivets went with one slab, and so they are sunk about 1/16 on one side. If they weren't sunk down so far I might just try to get a bunch of J B Weld in there. Can't do it with my fingers, but can squeeze it all back together with a vice.There's looks to be a little laha in there, but not a lot. But the slabs aren't really loose either (yet ??).
I'm thinking that Bondini superglue and the vice might be a temporary fix until I eventually try and drill out the rivets and reshape or replace the slabs. I don't want to use epoxy because I cant imagine that the horn will relax enough that the slabs won't eventually pop back out--with expoxy I might have to grind off a slab if one stays on and the other pops out again.
Any better ideas? Am I right about the horn?
