Help identify this 110 *SOLVED*
DeSotoSky
Recent interesting find. A Nickel Silver 110 with dark Macassar Ebony handles. No pivot or scale pins. D2 steel blade with a 2013 BCCI tang stamp. Other than the handles this knife exactly matches the blue and white Lucite 25th Anniversary 110. I can not find any info on this knife. The box it came in is not original to it so no help there. Does anyone else have a knife like this? A build-out using the 25th Anniversary blades?
That looks like it. Thanks. So it was a recent build-out of the 2013 25th anniversary blade.
0110BO42-B cat # 10989 build date 05/18/2016.
Boy, if they could only talk... how did it end up orphaned on a gun show table in St Louis so quickly?
I wonder if it came from the recent factory sale.
Has anyone compiled a list of all the 110 build-outs and their quantity?
I like both of them. :thumbup: DM
What does the sheath look like that came with it?
David, it came with a standard black leather sheath but the box it came in was not original to the knife so can't say for sure.
It is probably correct because the one pictured in D-RIG's link is also a black leather sheath.
This as far as I have got on a list. I do have some to add to it when I get time. Combined my info and some from Joe Hauser and D-RIG. It shoud be noted that BO30-BO33 include a tin, and all have the same knife.
UPDATED 1/16/2017
0110BO-B FOLDING HUNTER (BUILD OUT),NANOSTEEL COATED BLADE 9
0110BO1-B FOLDING HUNTER (BUILD OUT),BUGLING ELK C/O (A8),NYLON SHEATH 196
0110BO2-B FOLDING HUNTER (BUILD OUT),CHAMPAGNE COATED/SERRATED BLADE 7
0110BO3-B FOLDING HUNTER (BUILD OUT),DEER HEAD C/O (B14),NYLON SHEATH 583
0110BO4-B FOLDING HUNTER (BUILD OUT),DEER HEAD C/O (B13),NYLON SHEATH 31
0110BO5-B FOLDING HUNTER,G-10 HANDLE,NS BOLSTERS,BG-42 BLADE,BOX 1
0110BO6-B FOLDING HUNTER (BUILD OUT) CHARCOAL DYMONDWOOD HANDLE,BOX 190
0110BO7-B FOLDING HUNTER (BUILD OUT) APPLE CORAL HANDLE,DEER CUTOUT,BX 25
0110BO8-B FLD HNTR (BUILD OUT) MACASSAR EBONY/BRASS HDL,ELK C/O ON BLD 104
0110BO9-B FLD HNTR (BUILD OUT) RECON-MACASSAR/BRASS HDL,ATS34 SERRATED 38
0110BO10-B FLD HUNTER (BUILD OUT) CHERRYWOOD/NS HANDLE,420HC BLADE,BOX 19
0110BO11-B FLD HNTR (BUILD OUT) RECON-MACASSAR/BRASS HDL,BEAR C/O BLADE 62
0110BO13-B FLD HUNTER SERRATED IDAHO STAMPED SATIN BLADE, BRASS BOLSTERS, PALMWOOD, LEATHER SHEATH 27
0110BO-14 BOX PINK ION-FUSION BLADE, WALNUT INLAY, BRASS BOLSTERS, LEATHER SHEATH 36
0110BO-15 BOX GOLD ION-FUSION SERRATED BLADE, BRASS BOLSTERS, IRONWOOD INLAY, LEATHER SHEATH 12
0110BO-16 BOX BCCI STAMP, SATIN S30V BLADE, JIGGED BUFFALO INLAYS, BRASS, LEATHER SHEATH 30
0110BO-16 BOX MACASSAR EBONY BLK 560 BLADE LEATHER SHEATH 50
0110BO-17 BOX SATIN FINISHED BLADE, ELK HANDLE, BRASS BOLSTERS, LEATHER SHEATH 17
0110BO-18 BOX SATIN FINISHED BLADE, G10 HANDLE BRUSHED N/S BOLSTERS, BROWN DISTRESSED LEATHER SHEATH
0110BO-18 BOX CPM-154 BEAD BLASTED BLADE, G10 HANDLE BRUSHED N/S BOLSTERS, BROWN DISTRESSED LEATHER SHEATH
0110BO-19 BOX SATIN FINISHED BLADE, G10 HANDLE BRUSHED BRASS BOLSTERS, DISTRESSED BROWN LEATHER SHEATH
0110BO-20 BOX IDAHO STAMP SATIN FINISH SERRATED BLADE, BLUE INDIGO HANDLE BRASS BOLSTERS, BLACK LEATHER SHEATH
0110BO-21 BOX STONE WASHED BLADE, KOA WOOD HANDLE BRASS BOLSTERS, BLACK LEATHER SHEATH
0110BO-22
0110BO-23 BOX BUCK CUSTOM TITAINIUM NITRIDE COATED BLADE, CHERRY DIAMONDWOOD HANDLE N/S BOLSTERS, BLACK CORDURA SHEATH
0110BO-24
0110BO25-B 154CM BLADE, RED JIGGED BONE HANDLE, NS BOLSTERS, BLACK CORDERA SHEATH
0110BO26-B 154CM BLADE, BLUE FIBERON HANDLE WITH BUCK SHIELD, NS BOLSTERS, BLACK CODERA SHEATH
0110BO27-B 154CM BLADE, GREEN SMOOTH BONE HANDLE, NS BOLSTERS, BLACK CODERA SHEATH
0110BO-28 BOX SATIN FINISH BLADE, G10 HANDLE BRASS BOLSTERS, BLACK CORDURA SHEATH
0110BO-29 BOX SATIN FINISH BLADE, WALNUT HANDLE BRASS BOLSTERS, BLACK CORDURA SHEATH
0110BO-30 BOONE & CROCKET THEODORE ROOSEVELT TIN, SATIN FINISH BLADE, WALNUT HANDLE BRASS BOLSTERS, BLACK CORDURA SHEATH
0110BO-31 BOONE & CROCKET MULE DEER TIN, SATIN FINISH BLADE, WALNUT HANDLE BRASS BOLSTERS, BLACK CORDURA SHEATH
0110BO-32 BOONE & CROCKET WHITETAIL DEER TIN, SATIN FINISH BLADE, WALNUT HANDLE BRASS BOLSTERS, BLACK CORDURA SHEATH
0110BO-33 50TH ANNIVERSARY TIN, SATIN FINISH BLADE, WALNUT HANDLE BRASS BOLSTERS, BLACK CORDURA SHEATH
0110BO34-B S30V DROP PIONT BLADE, C-TEC HONEYCOMB HANDLE, COPPER BOLSTERS, BLACK LEATHER SHEATH
0110BO35-B BOX FLD HUNTER 420HC IDAHO 10 STAMP PINE GARNET INLAYS, BLACK CORDURA SHEATH
0110BO36-B BOS 440C HORIZONTAL STAMP, RED PAPERSTONE HANDLE, BRASS BOLSTERS, BLACK LEATHER SHEATH
0110BO37-B BOS 440C 50TH ANVIL STAMP, WHITE SMOOTH BONE HANDLE, BRASS BOLSTERS, BLACK LEATHER SHEATH
0110BO38-B FLD HTR BURLWOOD 420HC MIRROR ALFRED C BUCK ETCH N/S HDL BROWN LEATHER SHEATH
0110BO39-B
0110BO40-B FLD HNTR FIJI ORANGEWOOD 420HC DEER C/O N/S HDL BLK LEATHER SHEATH
0110BO41-B FLD HNTR FIJI ORANGEWOOD 420HC BEAR HEAD C/O N/S HDL BLK LEATHER SHEATH
0110BO42-B FLD HNTR D2 BCCI MACASSAR EBONY N/S HDL BK LEATHER SHEATH
0110BO43-B FLD HNTR FIJI ORANGEWOOD S30V DROP POINT BUCK ANVIL STAMP N/S HDL BLK LEATHER SHEATH
0110BO44-B FLD HNTR INDIGO 420HC STONEWASH BUCK ANVIL BRASS HDL BLK LEATHER SHEATH
Here are some of the Buildout knives that are not on your list , please add them .
you should be able to copy and past them , please spell check before you do .
0110BO-25 154CM BLADE, RED JIGGED BONE HANDLE, NS BOLSTERS, BLACK CORDERA SHEATH
0110BO-26 154CM BLADE, BLUE FIBERON HANDLE WITH BUCK SHIELD, NS BOLSTERS, BLACK CODERA SHEATH
0110BO-27 154CM BLADE, GREEN SMOOTH BONE HANDLE, NS BOLSTERS, BLACK CODERA SHEATH
0110BO-36 BOS 440C HORIZONTAL STAMP, RED PAPERSTONE HANDLE, BRASS BOLSTERS, BLACK LEATHER SHEATH
0110BO-37 BOS 440C 50TH ANVIL STAMP, WHITE SMOOTH BONE HANDLE, BRASS BOLSTERS, BLACK LEATHER SHEATH
I decided to start another thread on the subject of 110 Build Outs to make it easier to find if someone does a search. Thanks for this tread DeSotoSky.
