- Feb 26, 2016
I heat treated four N690 blades and six AEB-L blades, all of which came out straight as an arrow. Then the problem, all four of my A2 blades came out with rather severe warps, only one of which I was able to bring back within tollerance, by clamping during temper. I've been seeing this a lot with A2 and from different material providers so I'm certain there is no issue there. All the blanks were profiled, drilled, and put through a two hour stress relief. no other prior grinding was performed, stock thickness was .150. My kiln is an even heat KO, 22.5" deep. 1200-equalize, 1400-equalize, 1750 hold for 20min, steady to the plate vice. Every blade warped in the same direction. I could stack them on top of each other like a little U. Blades on one side didn't seem to warp worse than others so I'm not sure if it's a kiln problem, and if so, why wouldn't it effect the other knives? Hoping for a little help before I lose my mind.
