Thanks in advance for any help identifying this tomahawk or hatchet. A friend passed it on to me. I don't see any identifying marks. I know the handle has been replaced.
I have the following questions that I hope some folks might shed some light on.
1. What is it? I'm guessing tomahawk based on the blade shape being more long and narrow. I'm also guessing the point opposite the blade indicates more of a tactical, or tacticool, intention? Does anybody recognize it as being made by a particular manufacturer, or is it likely imported? Is this a throwing Hawk?
2. What kind of handle should be on this? What length? Should it be permanently attached, or slipped on a handle so it can be easily removed?
I pass on the following novice observations. The finish, although it has specs of surface rust from storage in a damp place, is very bright. Almost like it was chromed, but it seems to be solid and not plated. The grind on the edge doesn't have a clear line. Very rounded, so I think it's a convex grind. What does that say? Modded, or likely original? The top edge is very rounded. Again, is this likely original or rounded off from a previous owner? It has a decent edge and I anticipate it will sharpen further to a very sharp edge if it's as good as it is after sitting in a damp garage for several years.
So what is the analysis from the experts here? If you don't mind a bit of schooling for a novice, I'd love to know what this is and more about it.
Thanks!
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Thanks!
