Help IDing a Mora
I saw a used Mora in use today, and can't identify what model it is. It has a painted red handle and a blade of about 4" long. There aren't any markings on the left side of the blade (where Frosts' and Eriksson mark theirs) but there is on the right side. It says MORA, with a C and A together between the O and R in MORA. There's a rectangular box surrounding the entire text, with half circles around the C and A. It's almost exactly the same as a Frosts' #1.
The sheath isn't plastic; it felt like hardened leather. It's stitched in the back, and is red in color. The front has the traditional Mora design that you see on the plastic sheaths. There's a small black leather belt loop attached in the back. It's attached via steel piece of metal.
I don't have any pictures, as I don't have the knife myself and I can't find a photo of it on-line. I'm mainly interested in what steel it is, and where I'd buy one. Neither Ben's Backwoods and Ragweed Forge have it.
EDIT: I've heard the CA stands for Carl Andersson, but I still haven't found a picture of what I'm describing.
Could it have been an early Mora #1? The ones made in the 1980s & earlier came with leather sheaths until it became too expensive. I have seen some and do own an early Fiskars that came with a leather sheath.
There used to be many Mora knifemakers until they closed/consolidated.
If you post this on the Scandi section of the "other" Forum, you should get a more detailed response.
