I always wondered how the little leather strop worked. Do you add compound or will it give a mirror polish out of the box?
I'd recommend the diamond stones, with a ultra fine and sapphire ceramics which have to be bought separately. They even have a leather strop. This will take of the steels you have and future steels. You should be able to get everything for around 100.00. That's what I use and it has served me well so far.
Definitely the diamond kit, I would wait until the end of this month or next month though. The updated kits should be out with rubber inserts and redesigned thumb screws (so you don't hit the front one while on 17 degrees).
I use the diamond medium and fine hones plus the yellow ceramic and blue sapphire polishing hones.
I bought the leather hone...not worth the money at all. Not flat and just does not do the same job a strop with compounds will do.
I use the hones on an elmax zt566 as the hardest steel but also on 154cm steel. The hones work great.
I'd say the most economical way to go is to buy the hones and wires rather than any kit. I never use the box the kits come in. I also bought an extra set of wires so each hone has its' own wire and they are all set correctly saving time having to do them over and over.
