wicked1 said:
I took a marker and marked the edge and stropped at about 13 degrees starting with 100 grit.
13 degrees is a little low for cutting metal. Convex edges are no different than v-ground edges in that you need to match the angles to the knife and steel.
When the edge looked straight again I switched to 220. Now I can cut paper but not very well.
Even if you are planning on moving to a higher grit then you definately want to get the blade to at least slice newsprint well, meaning it cuts with no tears/slip on a draw. If it isn't doing this then the edges don't even meet. It can also be made to shave and push cut newsprint at the more coarse grits with proper burr removal. All this means is to minimize the extent the edge deforms on most steels which is done by a combination of right pressure, short passes, alternating sides and elevated angles.
Generally you don't need to fully optomize the edge at every grit, but make sure every higher grit does make the edge push cut sharper and still retains strong slicing ability and that any burr is getting significantly reduced with each elevated grit. SR101 isn't prone to heavy burr formation, however if the edge is highly stressed, which sounds reasonable given it was rolled from metal cutting, that metal will tend to break off during sharpening as it is highly fatigued.
In general for a knife that does really heavy cutting, the performance pretty much levels once it slices newsprint well. You won't notice it chopping any better if you go from that to actually shaving above the arm. The edge retention will be higher the sharper you get the knife however no one bats a 1000 when you first pick up a bat.
I am just about ready to say screw the convex and just throw it on the sharpmaker or my edge pro and be done with it at a 21 degree V bevel. Will I lose much performance in doing so?
You won't notice any different in cutting ability unless you do carefuly measurements on very thin and hard materials and the edge will be more resistant to damage. Most sharpening guides for chopping blades will recommend a very light microbevel for exactly this reason.
wicked1 said:
Yeah I get the burr on both sides. I was using my leather strop to take it off after it had formed on both.
This generally isn't a good idea, it often causes the burr to crack off. Plain leather is mainly just a cleaning agent for knives, especially those which are hard and/or wear resistant.
-Cliff
