Help Me Decide...
Been looking a t purchasing one of two items, an Edge Pro Apex or a Lionsteel SR-1... I can't decide which of the two to get and could use a little prodding in either direction.
Well, that all depends.
Do you NEED a better sharpener or does the one you currently have work well and provide you with the sharp edge you need?
If you really need the sharpener because you're not getting a good edge, then by all means, get the sharpening set up.
If you don't need it to get a nice edge that you're pleased with, then get the knife.
I would get the knife, but that's just me.
I've got a sharpmaker and a couple of leather strops that produce a good edge as long as I don't have to re profile anything. In that case, it's still doable, but takes much longer than it should.
How many knives do you own? If you own alot I would get the edge pro, if you only have a few I'd go for the knife.
Five knives total at the moment with a sixth on preorder (surprisingly no fixed blades at all).
If you have a knife you like a lot already, get the Edge Pro first, and then the knife.
Connor
The Benchmade 710 is for sure a favorite, enough that I had some custom work done to it and it sees the most pocket time by far.
