Help me decide...
Should I get the Zero Tolerance 0200 or 0350. I have never seen them side by side but they seem to be very similar with differant types of scales. What to do what to do.
After owning both I felt like I got way more than my money's worth out of the 200, and pretty much just my money's worth from the 0350.
If you can handle a heavy, 4" blade folder then the 0200 is awesome for the price.
I think I like the AO better than the flipper type, but that is either here nor there. I would get used to it either way. Is the 0350 that much smaller than the 0200? I thought the specs showed them pretty close although it I know that can change side by side.
You might as well, get both, and be done with it. I think they are the best folders, being made today!
ZT0350:
Blade - 3 1/4"
Closed - 4 5/8"
Weight - 4.8 oz.
ZT0200:
Blade - 3 7/8"
Closed - 5 1/4"
Weight - 7.7 oz.
Just judging by the specs, the 200 is quite a bit bigger and significantly beefier.
ZT0350:
Blade - 3 1/4"
Closed - 4 5/8"
Weight - 4.8 oz.
ZT0200:
Blade - 3 7/8"
Closed - 5 1/4"
Weight - 7.7 oz.
Although the ZT 0350 is listed at "4.8 oz.", per "Thomas W.", it is actually 6.2 oz. So, the big question is, is 1.5 oz. less & a little over 1/2" shorter blade & handle better suited to you for an EDC?
Good luck.
