I have a very very simple problem that hopefully has a very simple answer. I bought a benchmade 940 about a month or so ago and have been very happy with it in every aspect except for its sharpness. It came to me not sharp enough to shave hair, and it took me several days on a sharpmaker to get it to that point. I attempted to put on a 30 degree back bevel with a 40 degree microbevel. unfortunately, the blade lost its shaving-sharpness over a few weeks of light use cutting up cardboard boxes, paper, and carving wood while camping.
I recently used a sharpie to cover the edge of the blade before using the sharpmaker, and I noticed that while one side had its sharpie removed almost immediately, the other side only had its sharpie removed along the shoulder, leaving the very edge still covered. I initially suspected that I had overdone it with the microbevel, and decided to ditch it in favor of a 30 degree edge, but after literally thousands of swipes on the course stones over a few days, the edge seems to be in exactly the same condition.
This leads me to wonder if I am making a mistake by sharpening both sides equally. In order to correct for the blunter angle on one side, does that mean that I should sharpen only that side until I can take off all of the sharpie before I resume sharpening both sides equally? I have not yet been able to remove
The course sharpmaker stones seem to be almost useless for the task of grinding down shoulders. In frustration with the lack of results I have been getting (I can only shave with pressure, the edge reflects light under a light source, and gets snagged or rips when cutting paper) I ordered a set of diamond rods for the sharpmaker today.
Anyways, I guess I am just looking for any input you guys can give me on correcting the uneven edge angles. I think I am going to ditch the microbevel idea for now (I always fear that I am overdoing it and messing up my edge) and just go for a 30 degree edge. I just want to be able to justify carrying around my 940 osborne, as it is such a beauty of a knife, but I just can see myself doing that when my 30$ tenacious seems to be twice as sharp as it is. As mentioned before, my main question is whether I should sharpen both sides equally when re profiling to 30 degrees, or if I should only focus on the side that is too thick? I tried a search of bladeforums through google, and found several threads about uneven edge angles, but non of them seemed to include step by step info on correcting them, speciffically with a spyderco sharpmaker. Do you guys think that the diamond rods will do the trick when they come in a few days, or is it possible that I am just doing something wrong? Just for backround info, I have used the sharpmaker to get great edges on other knives, especially spyderco's.
Thanks in advance,
JonM
PS. Do you guys know if cutting paper will dull your knives unusually fast? I get knife OCD at times and will sometimes fill up half of a wastebasket with paper ribbons in a night. I will wander around the house half-asleep at three A.M. and cutting up magazines and scratch-paper while intermitantly attempting to shave my leg hair as if cutting up everything in the recycle bin will make the blade sharper.
Thanks in advance,
JonM
