- Nov 5, 2009
I have been reading on survivaltopics.com about how I need to have a good knife as a part of any good survival kit. I am going camping next weekend and will do so again plenty more times - I am buying a good folder and also want a good fixed blade. So I was thinking of buying a good survival knife like recommended on survivaltopics.
BUT:
They recommend more than one option!
Apparently survivorman Les Stroud carries a Buck Special 119 - # Blade Length: 6" (15.2 cm)
# Blade Material: Satin Finish 420HC Stainless Steel
# Carry System: Black leather sheath
# Handle Material: Phenolic
This would cost about $45 which isn't too bad.
They did recommend a SOG Seal Pup
# Blade Length: 4.85"
# Overall Length: 9.5"
# Weight: 5.4 oz.
# Edge: Straight
# Steel: AUS 8
# Handle: Zytel
This would cost about $78 and I suppose I could stretch the budget that far.
They also recommended a KA-BAR Becker 7"
# Blade Length: 7" 1095CroVan
# Overall Length: 12.75"
# Blade Thickness: 0.188"
# Blade Coating: Black epoxy powder coat
# Grind: High, flat saber grind
# Handle Material: Full tang, Grivory
This one is $76 - so similar to the SOG
Hmm - they all seem nice and capable knives. The Becker has a 7" blade which would be better for some tasks, but is that too long? The Buck has a 6" blade, maybe a better size? Is the SOG's 4.85" blade big enough?
I am kinda leaning towards the bigger one because I will have a folder with a smaller blade (probably an Endura with 3 3/4" blade) that I can use for things that a 7" blade is a bit much for. I also have an Ontario Rugged 9" knife with a 4" blade on order - only $14.95, so that is a smaller fixed blade knife.
So, any reason not to go with the Becker 7" for a good fixed blade knife?
BUT:
# Weight: 5.4 oz.
# Edge: Straight
# Steel: AUS 8
# Handle: Zytel
