If you just want profiles, you can put your knife on a flat bed scanner and get a better picture than you ever will with a camera...and scanners are cheap. I know, I've tried it both ways. Here's a knife on a scanner:
It's an antique knife, to be sure, but the scanner picks up every detail as you can see. Of course this doesn't work if you want background settings. Then you are going to have to set up lights and put the camera on a tripod. I would guess the kind of camera you want for that is probably going to start around $1000.
For 10x magification, you would need a SLR, a micro lens and a bellow. Not sure if the bellow is enough to get you 10x thought. Might need a microscope for that. Lots of lights all around the lens would definately help.
Think you need to add another 0 at the end of that figure.
singteck
Here is a link to some really upclose stuff that goes a little beyond the QX5. The QX5 sounds easy though:
http://knifeforums.com/forums/showtopic.php?tid/782537/tp/0/all/1/
