Help modding ti Millie
Ok, so I have a full ti Millie and I am looking to get an xhp sprint. I would like to know if it's possible to put the xhp blade in the ti handle. I would also consider making two "half and halfs" like the KW m4 Millie. What would be the best way to do this? Just take the lockbar side off the ti and switch it with the scale from the xhp Millie? Has anyone done this before?
People have done it, but there is no guarantee that pairing a blade from a liner lock millie with the lockbar of a RIL millie will work and be safe as the lockbar is mated to the blade tang. You might get lucky. Swapping blades between two liner lock millies is less problematic, as you are essentially swapping scales.you could definitely put the non-locking scale of the Ti millie on the xhp one, and vice versa.
