I want to reduce the width of my OKC Ranger RD4's Micarta scales by about a 1/16th of an inch. Is it possible to do so with an industrial sander or grinder and then finish with some sandpaper or would this somehow ruin the Micarta?
I've worked with micarta for over 20years.If you use new abrasives it helps alot. Worn belts tend to burn it.Suggest a 120 grit to take it down. Then you can hand sand. a 220 grit will still leave a grabby feel to it.I've been using filter masks and they've worked well so far.
