- Apr 30, 2010
I read the sticky's however I decied to try to heat treat my first 2 knives made out of 1095. I know it is harder to heat treat than say 1080. I heated it to non magnetic then let it go little longer. I quenched in veg oil. I know it wasn't the best methods but these were knives I am learning to grind and get a feel with. I figured I wouldnt get the full potential out of the steel.
I tried the file test seemed ok thought it might be just the scale coming off. I grounf the scale off and put a edge on it. I did the brass rod test and if I did it right it failed bad. I also checked two other knives one a ontario knife made out of 1095 it passes. The other a benchmade out of 154 it failed as bad as my home made knife. Which doesnt surprise both of the benchmade with 154 has failed most test I put them up to. I put the brass rod in a vise and blade at round a 20 degree angle and drew the knife using force to deform edge on brass. Did I do this right.
If I did all this right I need to find some one to heat treat the other knife. I haven't ground the edge down on it yet. I dont know of anyone around me that can do it so will have to send it off. Any help would be greatly appreacated.
