Help needed immediately
could you please tell me the rockwell hardness of these steels
H13, P20 ,D2, AISI 1045
Also their hardness values after hardening and tempering. I am really stuck with these things. could you plzzz help me out........
Howdy,
Welcome to BladeForums:
The Rockwell Hardness will vary depending on what tempering process (time and temperature) is performed. For example, IIRC, D2 ranges from 57 to 62, depending on how it is tempered.
Your best bet for specific temperature profiles and what hardness results from each would be by checking with steel manufacturers. But, you could also ask in the Knifemaker's General Shoptalk forum here:
http://www.bladeforums.com/forums/forumdisplay.php?f=741
Add: here is the Crucible Steel data sheet for D2:
http://www.crucibleservice.com/datash/ACFC3C.pdf?CFID=2079406&CFTOKEN=46197463
as quenched hardness
H13 - 51 to 54
P20 - 53 to 55 (can be carburized)
D2 - 62 to 64
1045 - 55
from the Heat Treater's Guide
