- Oct 6, 1998
Hello,
I just received from the US my Flat ground Sebenza and because of the nice cleaning manual from Ted Voorde and the movie from Danish Viking I decided to disassemble my Large Sebenza and clean it oil it and put it back together.
Well, I was able to unscrew the pivot screw and push out the pin and then remove the blade.
So far so good but of the remaining 2 handle screws only the backspacer screw&pin + backspacer unscrewed but the Stop-pin screw didn't unscrew it just rotates the whole pin and because it's so smooth at the opposite side I can't hold the pin with enough pressure so I can unscrew the stop-pin screw from the other side.
My guess is there's some hardened oil in the threads, no locktite though as both of the 2 other screws were also a little difficult and there was dried gummed oil in the threads making it difficult to unscrew.
What can I do to loosen the stop-pin screw as I want to completely disassemble my Sebenza and clean all the gummed residue from the stop-pin screw+pin threads so that everything screws together nicely. I already cleaned the other 2 screws and thread of the pins that I could unscrew and now everything screws together smoothly.
I don't really fancy sending it over to the US as it just arrived 6 hours ago.
I appreciate any tip
, could WD40 perhaps penetrate the threads of the stop-pin screw? or should I apply a soldering iron to the stop pin screw for a few seconds?
Best Scouting wishes from Holland,
Bagheera
Bagheera
