help needed to recondition stacked leather
Hey guy, do you have any suggestions how to recondition stacked leather handles that have dried out and show slight scuff marks? Any help would be appreciated.
I've not actually tried reconditioning stacked leather handles, but I've had good results reconditioning old leather things using Neatsfoot oil. (Bought it from a local hardware shop) Being a liquid instead of a waxy paste like Dubbin, it gets absorbed a lot faster.
Typically, what I'd do is brush off loose dirt, then wash the leather object using an old toothbrush and a warm emulsion of dishwashing detergent and Neatsfoot oil. Rinse in fresh warm water then pat dry. With a cloth, rub in the Neatsfoot oil (would be better if slighty warm, but not essential). Be generous and allow time for it to be asorbed. I usually allow 15min between each application and keep it up until the leather feels soft and supple, then finish off with a couple of coats of Dubbin rubbed well in with the fingers. The Dubbin is optional.
Since you are working with stacked leather handles, I don't think you should be waiting for it to get supple
But hopefully, here's a starter and people with more experience might chip in. As always YMMV.
How big are the gaps between the leather "chips"? Everything Steelwolf has said makes sense to me, but I would add that since the leather is currently dry (& has consequently shrunk) you ought to be reconditioning it from the inside to the outside, rather than the other way. It would take less time to complete, and possibly reduce the chances of "internal" damage to the leather. If you can't get to the inside surfaces of the leather, but the leather is in dire need, remove the pommel (or have someone do it for you) and then the handle, numbering the discs so they go back on the same way the came off. Then continue as Steelwolf described, before re-assembling the handle. Make sense?
Sometimes I get the idea that everything is ulterior ...
Scuff marks can be sanded out. I've used linseed oil for dried out washers, neatsfoot oil should work also.
Paul
