help needed ; what fsh busse do I have ?
R.G
As I did my search on the forums for what I think is hogfsh busse I found out most of you guys think there is no such thing 0.32" saber grind fsh ,as you can see it is saber for sure and it is 8 mm thick so it's not the 0.27" saber grind hhfsh ,
so what is it that I am holding please ?
thank you for your help
20130818_114809.jpg20130818_114822.jpg20130818_114854.jpg20130818_114923.jpg20130818_115004.jpg
ok guys so what is the verdict ?
how meny made ?
Hi , I have a nmfsh cg and it's 9.5" blade , this one is 8" blade so I think it's not nmfsh
I was told all hogfsh where ffg
What's ffg????
What's the exact thickness? Check butt thickness, as well as spine thickness.
I think you might have some kind of extravaganza or show special.
The "wild" handle color suggests to me that it is not an original FSH, in any configuration. But I could be wrong.
That's one I saw in x not long ago. I assumefd it was hh due to saber but obviously I was wrong as the seller stated after my post it was .32"
Its a new release I'd say either from Kc or blade cause the black and yellow is relatively new.
It maybe one off or one of very few.
I'd call it a saber ground HOFSH
CONGRATS
CONGRATS
Thank you knife hunter , yes it's the one you saw , I thought it's hhfsh to , I wanted a user but that one will be safe queene I think
It looks like it's .31 and that will make it a CG HOGFSH (Combat Grade Heavy Ordnance Grade Fusion Steel Heart) if it's .27 it is a HHOGFSH (Heavy Heart Fusion Steel Heart)
Oooops didn't see you there bro, i was also wondering about the black and yellow, do you know when they started using it.
CONGRATS
All good my friend:)
Last years blade 2012 I believe
Aztim got some of first I think. First remember seeing at blafe for sure but not sure if 2011 or 12 as they've started running together.
Pretty sure it was Tim and last year whrn he got the cg nmshbm
I THINK IT'S A FAKE BUSSE :eek:
LET ME KNOW YOUR ADDRESS, I WILL PICK IT FOR PROPER DISPOSAL:D
Might have been done with that small run of Saber ground Fat ASH1s I've seen.....
It without a doubt came from either blade 2012/2013 or the last spring or fall knob. Major Kong should be able to tell you for sure since he was the original owner.
