Help needed with damascus
I just bought an 8" piece of damascus made with 1084 and 15N20. It is 1 1/8 inches wide by 1/4" thick. I would like to get two blades out of this piece. It is possible to make two narrow tang knives by welding on a piece of threaded rod onto the tangs and if possible do I weld on the rod before or after heat treat? I also need someone who can heat treat these two blades for me. Thanks in advance for the help.
Marcel
Hi, If it were me I would reforge it wider and thinner maybe even longer. I will do that if you like. There is plenty of steel there but too thick. I have a hydraulic press that would make short work out of it. Also have a brand new even-heat oven on the way for the heat-treating when you are ready. Bruce Bump
pawnbroker yes you should weld on the tang before you heat treat i can heat treat it for you if you need it as i make all my damascus from 1084&L6 i use an electric oven to do all my heat treating
All that is not Given Is Lost
Please don't use all thread. You will have stress risers in the threads, and your tang will fail. A better solution is a grade 5 bolt, cut the head of and weld the smooth rod onto the blade. Even better,IMHO is to cut a piece of flat steel to match the blade then forge the tang end round, and thread it, saves a lot of fitting problems in the guard area. Forging the tang from the blade is better yet.
If God did not intend for us to eat animals. Why did he make them out of meat?
Hey, this gives me an idea. Ok, it's probably a crazy idea, but it is an idea. Whats the chances of taking a piece of 1/4" thick annealed damascus, setting up a fence on the bandsaw, and slicing it in hanlf thickness wise?? Anyone ever tried that??
Always think of your fellow knife makers as partners in the search for the perfect blade, not as people trying to compete with you and your work!http://www.nebsnow.com/L6steel
Buzzards gotta eat, same as worms!!!
L6, Thats how we make mosaic damascus. But 1/4" doesnt give any margin for error. Mosaic is a loaf instead of a thin peice. I still want to forge it bigger and thinner. Bruce
I appreciate all the answers to my query. I will go with Bruce's advice and have it forged thinner and longer. I will really get two knives out of it that way. I have learned more on Bladeforums in the last few months than I could have learned in 5 years on my own. Thanks All.
Marcel
Aint it amazing Pawnbroker!!! I've never run into so many unselfish and helpful folks in one place in my entire life.
