- Sep 1, 2012
Hi everyone,
I recently bought a surface gringing attachment (OBM) to prep blades before ht (removing deep scratches in material) and to finish the flats post ht. Yesterday I took the grinder out and cleaned all of my AEB-L blanks on it before going back inside and realizing I had messed up
. I used a 120 grit belt and light pressure, it wasn't throwing sparks and advanced the chuck only when the blade almost stopped touching the belt. The measured thickness from front to back is pretty decent but where it hurts is the variation on the other axis (blade height). For a handle +/- 1" high, I measured a high spot about +0.003" in the center. With the sides convexed there will definitely be an issue with handle scale gaps on the top and bottom.
In order to try and fix it, today I tested the following without any success:
-Swapped the contact wheel for another one I had and reground the mag chuck
-Tried operating at half speed instead of 100% (3500rpm motor with 6" drive wheel)
-Used different pressures, from lighter than yesterday to 'I gotta be careful, because it might grab the blade'
-Tried a 60 grit ceramic belt and a 220 grit structured one (much thicker)
-Adjusted the arm in order to get a bit more tension on the belt
Is there something I missed or am I asking too much from it ?
If you have any suggestions or tips, they're all welcomed and if the concensus is that nothing better can be achieved with it, is it realistic to believe that the blades could be salvaged by one of the pro ht'ers here that uses a full size surface grinder ?
Thanks,
Gab
Thanks,
Gab
