As a chemist with several decades of "cleaning technology" background, here's how:
1. Avoid water (and soap) on a folder. It's too hard to get it absolutely dry so it's apt to rust...even "stainless".
2. Slosh it around in a petro solvent, WD-40, turpentine, Zippo lighter fluid, diesel fuel, etc, and work all the moving parts while the solvent's dripping off.
Avoid anything with acetone, MEK, tetrohydrofuran (PVC solvent) etc, as these are apt to attack the plastic scales.
3. Repeat #2 until everything works smoothly and the solvent drips clear...ie, all the grit is out.
4. Slosh-rinse with denatured alcohol ( not 'rubbing' alc. which is ~30% water).
5. Blow dry with a hairdryer (on 'warm' to avoid condensation).
6. Lube with the oil of your choice.
This works 'cause the petro solvents have very low surface tension and float away grit, etc but don't have any water to promote rust later. The alcohol removes all the solvent traces then the air-blow removes the alcohol.
JMH
