You're probably referring to this from the Lifetime warranty sticky:
I find that the sweet spot actually extends a bit further back towards the belly on most khuks, but YMMV as it really depends on the kami who made yours as well as the individual khuk. The rest of the kukri isn't actually poorly hardened - just less hard than the sweet spot: probably HRC 45-54 while the sweet spot is HRC 58-62. You can use your kukri however you like, but during heavy chopping, the "sweet spot" will "bite" deeper, giving you the best results for energy spent while also suffering less deformation than other sections would. I'm personally a strong believer in proper technique, and getting into the habit of this makes you more effective at your task.
As for usage, I made this color coded diagram up to break things down:
First off, let me explain my sharpening method:
I personally convex my kukris razor sharp all throughout (mousepad/sandpaper method up to 2000 grit then a .3 micron chrom. oxide loaded strop). I also tend to increase the angle at the sweet spot to make it more resilient to heavy impact while leaving the rest of the blade more acute. If you've ever read John Lofty Wiseman's "SAS Survival Handbook," he favors Parangs that are (IMO) kukri shaped and suggests deferentially sharpening it to give different "working areas." I'm a strong believer in this method for large knives, as it makes a knife stay sharper for a longer period of time (it's even more apparent with kukris that are deferentially hardened).
On with the actual explanation of the colored areas:
Blue: the tip and although not as "soft" as people seem to make it sound, its being directly next to the sweet spot makes it prone to very hard impacts if not handled correctly (hence making it seem "soft" through juxtaposition to the sweet spot). I personally don't make much use of this area except during slicing actions (like if you were to gut an animal, slice up some onions - or perhaps slice the packaging tape to a box containing yet another kukri
). Being the point of the knife, I guess it's also what you'd use for a stabbing action, but I've never found myself needing to use a khuk for such a task.
Green: The "sweet spot" or hardest area and the only real area you want to use for heavy chopping. Although I sharpen this section to the same level as the others, I tend to increase the angle of sharpening ever so slightly here, making it less prone to deformation during heavy chopping tasks. Obviously since it's the hardest section, you can use it for pretty much any other task you see fit. Also, being the only section of the blade that naturally makes contact with what you're cutting (when perpendicular), you'll end up using this area extensively - especially if you find yourself using your khuk in the kitchen
Yellow: Belly of the blade. I use this area for lighter vegetation - from grass up to smaller branches. Since I sharpen this area more acutely than the sweet spot and since it doesn't suffer deformation from hard impacts (impacts that should exclusively be handled by the sweet spot
), it has an easier time slicing through springier objects instead of pushing it away like the sweet spot will tend to do. The overlap into the green area in my diagram just means that I inevitably use that area for these tasks as well (when swiping at a patch of grass for example) but for reasons already stated, the full yellow area is more suited.
Red: The recurved area - my #1 use for this area is draw cutting (by gripping the handle of the knife with one hand and the spine towards the tip with the other). Since it's curved and sharpened acutely, it does a great job at stripping bark or shaving wood when used like a draw knife. I also occasionally grip the kukri by putting my pointer around the cho and my thumb on the spine to use this area as I would a regular knife. Lastly, reverse this grip (thumb on/near cho, fingers on spine) and you're in a great position for peeling fruit (if you have a lighter kukri and/or your wrist and forearm can take it
Hope this info on my personal usage was helpful and I'll be glad to elaborate if asked. That all said, enjoy your kurki! It's an amazing chopper as I'm sure most will already know - but as I've explained, it's also an incredibly versatile knife once you get the hang of it!
