- Feb 4, 1999
I got my little peiece of steel from Tbark yesterday and it is L-6. I started grinding it right away on my 30 grit bench grinder wheel and I noticed right away that it is WAY easier to work than D-2, and it throws tons more sparks than the D-2 I've worked with. The D-2 I've used was very hard to grind, and this L-6 just melts away! Awesome! Anyway, it shouldn't be too long before I have the thing fully ground. I know the basic essentials of heat-treating steels, like leaving the edge thick to prevent warping, etc. What I need to know is can I oil-quench this steel to develop a nice differential temper and visible temper line? IF so, do I use a torch (will propane work?) to take it to non-magnetic, then quench the edge? Also, is there a benefit to multiple cycles of heating to non-magnetic and quenching? If so, how many times should I do this? When it is time to temper, what ytemperature should I use? I'll be using a kitchen oven, so consistency of the temp won't be too good, but it's all I have to work with (I don't cook at my apartment, so I'll use the oven there!). Any other tips will be much appreciated....
My Knife & Sheath Pages:
http://www.geocities.com/CollegePark/Lab/1298/frames.html
Palmer College of Chiropractic
Sheath Makers Referral Directory
agocs_s@dd.palmer.edu
Madpoet (Mel Sorg, Jr.) Tribute page:
http://www.geocities.com/CollegePark/Lab/1298/madpoet/main.html
