- Jul 31, 2002
Hey all.
I'm helping look for a ceramic water stone that will mainly be used on a Phil Wilson S30V fillet knife for a friend. We've experimented on it with several different edge types and finishes left by coarse through fine grits, and he really seems to love the mix of toothy bite and polished push cutting ability left by my Shapton 1000 grit slip stone. Note that this is after the Shapton has been lapped on a very fine (worn out) diamond plate- this stone behaves very differently when freshly lapped vs. letting it get a bit worn to expose fresh grit. The scratches are way more coarse when it's a bit worn.
Also, this knife has a very thin edge and minimal edge bevel- it was practically zero ground and then kissed with a coarser stone to form the edge bevel. And, I like using micro bevels for touch ups and in general. Primary sharpening is done at less than 10 degrees per side, with a mircobevel around 15 or so to give it stability to cut through fish rib bones.
So he needs a very hard stone. The edge bevel isn't wide enough to really ride on with a soft stone, and I tried my Norton 4K/8K combo stone on it once, but the Norton is just way too soft for this application and gouges horribly when trying to apply the microbevel. (It works great on my antique straight razors though).
I've been trying to read up on options here, so let me know if I'm on the right track.
It sounds like the Shapton Pro series is about the hardest ceramic waterstone available, and the Shapton Glass stones are a bit softer & wear faster. Is this correct?
Next choice is the Bester- I've also read these have a hard binder. They're cheaper than the Shaptons, so if there's not a lot of difference we'd probably go this route.
Choceras also sound like they have a hard binder. How do they compare to the two/three above?
From what I've gathered, the King and Naniwa stones, and most of the J-nats would be too soft for this application.
Thoughts welcome.
Thoughts welcome.
