The blade tension on my BM635 was pretty tight, so I attempted to loosen the pivot screw a bit. It turned some (a little too much actually), and then froze up. Now when I try to tighten or loosen the screw, the opposite side merely turns as well, and there's no way to secure it. As it is, the frame is now a bit loose, and the blade lies to one side when closed. How can you adjust the screw when there's no way to lock the other side? Do I need to send this to Benchmade? It seems silly to have to send a knife back to the manufacturer just so that they can tighten a screw!
Thanks a lot for your help!
