Help! Rust removal on an abused drill press?
I know we've covered various rust protectants for knives, but today my father asked me about the best method or substance for removing a lot of rust on a large drill press. Seems his suffered while stored in an outdoor tool shed of some kind, and he hopes to remove a LOT of rust, rather than simply protect the device against future oxidation.
Any suggestions?
Thanks,
Razor
AKTI #A000845
And tomorrow when you wake up it will be worse.
I was going to suggest dismantling the press and sandblasting the rusted areas .... but TOMBSTONE beat me to the punch.
Is that an option?
“Belül szívem hibád az örökkévaló erõs vastartalmú sok vasaló és orvosság."
Crushing the weak since 1970 .... the Demon has spoken.
You know, I'm not sure. I suspect Dad is hoping for something less labor-intensive than dismantling and sandblasting it -- but don't honestly know if that would damage the machine in any way.
Razor
AKTI #A000845
I wonder if there is a rust-sealant paint in an aerosol can that can be applied to coat the rusted area as well as prevent further damage .... ?
Just a thought ...
I've refurbished a few old machine tools and have found that 3M Scotchbrite pads lubricated with WD-40 work real well for removing even fairly heavy rust. Sand blasting will probably give you a rougher surface finish than you desire, particularly on areas of the machine that are left unpainted, such as the table or the column.
I am a woodworker and have refurbished several older woodworking machines. I'll back what X39 says. The scotchbrite type pads work well and wd-40 helps. Don't use Naval Jelly. Chem Prime can help but then you have to remove it. That's worth it if you have several tools to do.
Roger Blake
